Home » Sponsored » Pi Speakers » Fostex fe204
Fostex fe204 [message #37131] Tue, 02 July 2002 02:47 Go to next message
themonsteramp is currently offline  themonsteramp
Hi all!
I'd like to build a bass reflex speaker cabinet with 2 fostex FE204 full range speakers inside. Fostex show a 45 liters vented cabinet for 1 driver. Is it possible to double the internal volume (90l) and build 2 ports of the same dimensions? Is there other calculations, formulas?
thanks in advance
Re: Fostex fe204 [message #37134 is a reply to message #37131] Tue, 02 July 2002 10:42 Go to previous messageGo to next message
You can construct a cabinet having two chambers inside, each having its own port. Essentially, this is two separate Helmholtz chambers sharing a common cabinet. Or you can make a single combined chamber, with a single Helmholtz resonator - combined chamber and single port. Check out the PiAlign program; Just enter the quantity of drivers you intend to use.
Re: Fostex fe204 [message #37136 is a reply to message #37134] Tue, 02 July 2002 12:48 Go to previous message
Many thanks Wayne for your message. I'm gonna check out the pi-program.
Previous Topic: questions about one-pi speaker
Next Topic: This old dog learned a new trick......
Current Time: Tue Nov 03 12:30:34 CST 2026
