Home » Sponsored » Pi Speakers » Theater 3PI Enclosure plans...
Theater 3PI Enclosure plans... [message #37077] Wed, 26 June 2002 04:47 Go to next message
Danduq is currently offline  Danduq
Hello,
I would like to get plans for the Theater Pi3 speaker.
I would like to know which horn is used with the PSD2002 driver in this design. I looked at Eminence web site, but it seems they don't offer horns (or I haven't found them...) Where should I look for appropriate horns ?
I really liked your paper on crossover design, very good signal to noise ratio in there :,)
Thank you,
Daniel
You've got mail! [message #37078 is a reply to message #37077] Wed, 26 June 2002 10:08 Go to previous messageGo to next message
Re: Theater 3PI Enclosure plans... [message #37079 is a reply to message #37077] Wed, 26 June 2002 10:25 Go to previous messageGo to next message
Colin Fritzke is currently offline  Colin Fritzke
Daniel,
You want the Eminence H290 horn available from Parts Express:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=290-554
If you're in Canada, its also available from Q-Components (http://www.mcbrideloudspeaker.com)
Re: Theater 3PI Enclosure plans... [message #37082 is a reply to message #37077] Wed, 26 June 2002 11:32 Go to previous message
I was just about to give you that link! But looks like they beat me to it.
You can also use the Peavy CH-3 horn lense. I don't know if it matches the 3 Pi plans, but it's another option. I use it, they sound great, other than the two piece design isn't that attractive.
Adam
Previous Topic: You have to see this!
Next Topic: Wayne-Now you've seen and heard.......
Current Time: Wed Nov 04 04:31:10 CST 2026
