Home » Sponsored » Pi Speakers » wayne, adam, sam or anyone else who can run pialign
wayne, adam, sam or anyone else who can run pialign [message #36983] Wed, 19 June 2002 09:59 Go to next message
i want to put my pair of jbl 4655's to good use. as we all know these lack response below 80hz. i have a pair of omega pro-18 which i'd like to build cabinets for. i would place each jbl on top of each omega box. what is the smallest volume box i can build and still maintain good deep bass response. the speakers will be x-overed actively so i can play around a bit. also what is the recommended x-over point between the omega and the jbl woofer in the 4655? thanks in advance!
cheers,
george
PiAlign says... [message #36993 is a reply to message #36983] Wed, 19 June 2002 15:54 Go to previous messageGo to next message
Using your numbers, Fts=28, Vas=12.49 and Qts=0.24, PiAlign values are Frd=28, Vad=12.49 and Qd=4.17. PiAlign suggests making a 3 cubic foot box tuned to 44Hz. For a bass-reflex cabinet, actual dimensions are 26" x 18" x 12" and with a rectangular port having inside dimensions of 3 1/2" x 6 3/8" x 5 5/8" long.
Re: PiAlign says... [message #37000 is a reply to message #36993] Wed, 19 June 2002 18:24 Go to previous messageGo to next message
thanks wayne! a couple more questions. can i shape the box to resemble a cube as long as i stay close to 3 cu ft? also what is the -3db point for that box and at what frequency should i x-over to the jbl 4655's for best performance?
cheers,
george
Re: PiAlign says... [message #37003 is a reply to message #37000] Wed, 19 June 2002 21:00 Go to previous messageGo to next message
You can build the box cube shaped as long as you crossover low. Above 300Hz, a box this size made as a cube will have standing wave resonance problems. But if you crossover a couple octaves below that with a steep slope, it won't be a problem. I'd also suggest you crossover at or below the frequency where the distance between your sub and main speakers equalled 1/4 wavelength. So, for example, if you plan to crossover at 100Hz, be sure the sub and the mains are within 3 feet of each other.
Stage Series four π-18 [message #37004 is a reply to message #37003] Wed, 19 June 2002 21:17 Go to previous messageGo to next message
FYI - A PiAlign'ed Omega 18 is a Stage Series four π-18.
You have mail! [message #37005 is a reply to message #37004] Wed, 19 June 2002 21:22 Go to previous messageGo to next message
I've sent you a copy of the plans for the Stage Series four π-18, 'cause that basically what we're talking about.
Re: You have mail! [message #37006 is a reply to message #37005] Wed, 19 June 2002 23:51 Go to previous messageGo to next message
demanddeepbass is currently offline  demanddeepbass
Hi Wayne, could you copy a set of those plans to me as well? Thanks.
Olly
Re: You have mail! [message #37007 is a reply to message #37006] Wed, 19 June 2002 23:54 Go to previous messageGo to next message
Oh yeah, my adress is: spurlash@rya-online.net
cheers
Olly
You've got mail too! [message #37008 is a reply to message #37007] Thu, 20 June 2002 01:16 Go to previous message
Previous Topic: Could someone please send me the Plans for One Pi?
Next Topic: Disappearing acts, and music too
Current Time: Sun Oct 25 23:20:27 CDT 2026
