Home » Sponsored » Pi Speakers » What are you using for amplification?
Re: What are you using for amplification? [message #36962 is a reply to message #36953] Tue, 18 June 2002 11:52 Go to previous messageGo to previous message
goldengate is currently offline  goldengate
Hi:
I am basically using two separate systems. I am matching my Pi Studio 2's with one of two SET Amps - Welbourne Laurels 300B's or Wavelength Gemini 45's. I love the SET tube sound with the Pi's. They match very well.
I also have a ribbon hybrid speaker (Newform Research R645) that I match with a Solid State Odyssey Stratos Amp.
Basically, I listen 75% of the time to the SET/Pi combo. However, when I need to get some "slam", I move over to the Newform/Stratos.
If I ever move to a much larger place, I would love to try out a larger Pi speaker like the Theater 4's. They are a little bit too imposing for me now.
Previous Topic: How do you position your 4 Pi's in your listening room?
Next Topic: Absolutely amazing wood finish
Current Time: Sun Oct 25 21:08:33 CDT 2026
