Home » Sponsored » Pi Speakers » What are you using for amplification?
Re: What are you using for amplification? [message #36954 is a reply to message #36953] Tue, 18 June 2002 07:00 Go to previous messageGo to previous message
I'm using a SET 300B amp with a modified Foreplay preamp. My SET uses a 6N1P driver and a current source ala Gary Pimm. The output stage is conventional transformer loaded (not parafeed). This is an awsome setup -- with the speakers back against the front wall I had too much bass. I ended up pulling them about 2' out into the room. THey disappear nicely and the imaging is great but the depth could be a bit better. As for power amps I have also tried a 300B PP amp (25w) and a Leak Stereo 20 (wondering what the high NFB would do). In all cases, the SET wins hands down.
Steve
Previous Topic: How do you position your 4 Pi's in your listening room?
Next Topic: Absolutely amazing wood finish
Current Time: Sun Oct 25 21:10:25 CDT 2026
