Home » Sponsored » Pi Speakers » How do you position your 4 Pi's in your listening room?
How do you position your 4 Pi's in your listening room? [message #36939] Mon, 17 June 2002 19:03 Go to previous message
Finished the AR Turntable, re-assembled the flexi-rack, turning my attention to tweaking.
Using the center of the woofer as a reference, I've got mine about 50" from the front wall and 39" from the sides. 12X28X8 room. Moving them closer together actually frees the image from the speaker a little more but the depth collapses a little. Toe-in, about 10 degrees, seems better than perpendicular. Extreme toeing, pointing directly at the chair is bad.
Can't use Cardas, I'd have to listen from the dining table which is also my workbench.
Don't want to have them on the long wall a la Audio Physic, either.
'Audio Physic'; sounds nasty somehow, doesn't it?
Doesn't seem possible to make the beasts "disappear".
What works for you all?
Previous Topic: Premium Stage Four Pi Pictures!
Next Topic: What are you using for amplification?
Current Time: Tue Oct 20 13:54:06 CDT 2026
