| Can I build my Studio One Pi using 3/4" MDF? [message #36914] |
Sun, 16 June 2002 15:17  |
Erik Johansson
Messages: 65 Registered: May 2009
Viscount |
I´m wondering if it would work just as well using 3/4" instead of 5/8" MDF for the Studio One Pi cabinet. I can get 5/8" MDF but my friend who makes the pieces for me has some pieces of 19mm (3/4") laying around. I would of course recalculate the cabinet so that the internal size is exactly the same. /Erik
| Re: Which MDF thickness do you recommend? 5/8"? [message #36927 is a reply to message #36919] |
Mon, 17 June 2002 10:09   |
Erik Johansson
Viscount |
I found out that I'll have to buy MDF for this project anyway. So now I have the choice of going with any thickness. What do you recommend? Standard 5/8" would be 16mm with our metric system and 3/4" would be 19mm for me. I'm hoping I won´t have to brace the cabinet to get a top performing speaker, do I need bracing with the 16mm (5/8") MDF? /Erik
| 5/8" is plenty [message #36929 is a reply to message #36927] |
Mon, 17 June 2002 11:53  |
Messages: 19105 Registered: January 2001
Either would be just fine. As I mentioned in my last reply, just be sure that the port is the right length and diameter. When using a thicker panel, there is more length of "duct" simply due to the depth of the port hole cut into it. So please be sure to consider this when making your port, and make sure it's total length is 89cm.On the matter of bracing, the box is small enough that it is pretty solid without braces. Certainly, you can't be too solid so it wouldn't hurt to use the thicker panels or to add bracing. So you won't hurt yourself to go bigger or to add braces.
