Home » Sponsored » Pi Speakers » frequency vs. phase
frequency vs. phase [message #36918] Sun, 16 June 2002 17:14 Go to previous message
Jerry Parker is currently offline  Jerry Parker
Hi Wayne. Another question for ya. I was playing around with a signal generator on my computer, along with computer software called winisd, which you input theile small parameters and can find the response curves of different types of enclosures. Anyways, I put in the parameters for my enclosure for my big subwoofer along with the thiele small parameters and came out with the dual impedence peaks at 17 and 42hz. The box is tuned approximatly to 28hz. Now it is rather curious that the loudest note of the box is infact 42hz. That would tend to make sense, the resonant frequency of the enclosure is 42hz isnt it? Also, why is there two peaks? I assume one is for the port and the other for the driver? Minimum driver excursion is at tuning, and I get almost no cone movement at 28hz. The most excursion seems to be below tuning and 10hz above tuning, and a drop off of excursion after that. Does this seem correct?
Also, at the two resonant peaks of a vented box, why is the impedence so high? I know resonance is the frequency at which the driver radiates naturally, but if that is the case, shouldnt the impedence be very low at these frequencies? Thanks!
Previous Topic: Tent Sale!!!! 71125-01PWR-B=2226HPL for $100 each!!!
Next Topic: Info on buying and using a woodworking router?
Current Time: Tue Oct 20 03:27:32 CDT 2026
