Home » Sponsored » Pi Speakers » Reduce lenght of a JBL 2397?
Reduce lenght of a JBL 2397? [message #36913] Sun, 16 June 2002 12:59 Go to next message
spncer is currently offline  spncer
I would like to reduce the horn lenght of a JBL 2397 wood horn. The amount removed would be about 7" making the width equal to the cabinet width (Leaving the curved profile).
what effects would occured?
Thanks Spencer
Wood horns [message #36920 is a reply to message #36913] Sun, 16 June 2002 20:04 Go to previous messageGo to next message
This will raise the lower cutoff and increase ripples in the response. I suggest you model the horn using Hornresp to see.
You might want to check out Martinelli wood horns.
re:2397 horns [message #36926 is a reply to message #36920] Mon, 17 June 2002 09:28 Go to previous message
TimG is currently offline  TimG
If you don't like your 2397 horns I would sell them on ebay, or hold onto them, as the old JBL stuff only seems to increase in value. They regularly sell for $500 a pair on ebay. Then you could buy yourself some horns more suitable for your cabinets or build yourself a pair of the correct size out of plywood. Once you modify the 2397 horns they will have no resale value, and if they dont work out you will be out a set of horns and $500.
Previous Topic: Info on buying and using a woodworking router?
Next Topic: Anyone want to trade a pair of 2226H for my pair of 2226J?
Current Time: Tue Oct 20 03:22:40 CDT 2026
