Home » Sponsored » Pi Speakers » How is the One Pi dampened inside?
Piezo stuff [message #36875 is a reply to message #36874] Fri, 14 June 2002 08:42 Go to previous messageGo to previous message
For acoustic damping material, use R13 fiberglass insulation. I don't know if you have this designation in Sweden, but you can just find some that's 5-6cm thick. Put it on the bottom, back and the side nearest the port.
About the piezo, I don't recommend adding series resistance, at least not the series value that is shown by CTS as a protection device. By the time you get even close to damaging the tweeter, you've long ago destroyed the woofer/midrange. So it isn't necessary.
I used to install a very small value resistor in series, but I used it as a fuse and not as a current limiting device. And I was concerned about oscillation when I first considered using them too.
But after nearly 30 years of experience, I can assure you that these are unwarranted measures.
The kinds of circuits that encourage oscillation are unsuitable for use with piezo devices even with the resistor installed. Notice the previous post called "Don't go into clipping and check for back-EMF", where Andy reports that his piezo tweeters "buzz" (oscillate) even with the so-called protective resistors installed.
Previous Topic: Hi Wayne. Few more questions
Next Topic: Wayne, How about an Up-Graded Theater 4?
Current Time: Sat Oct 17 20:10:16 CDT 2026
