Home » Sponsored » Pi Speakers » Absolutely amazing wood finish
Absolutely amazing wood finish [message #36837] Tue, 11 June 2002 18:31 Go to next message
I may have mentioned 'Tried & True Original Wood Finish' before as an easy to use, pleasant product. I had just put single coats on things like the Paramour bases. I've just come home to the twenty-four-hour-cured second coat applied exactly according to the directions (!) on my quilted solid maple Flexi-rack and I'm in awe.
Bar none, it's the finest looking finish I've ever used. Feels silky, miles deep and the grain is more three dimensional than you could imagine. Classy low lustre. Antiquish.
Some caveats. Linseed oil is subject to spontaneous combustion and rags must be stored in water (baggies are good) before disposing. Also, Linseed tends to darken more than other oils so not a good choice possibly for cherry or mahogany which darken a good bit on their own.
OK to use on cherry that has been treated with a wash coat of tinted shellac which it should have anyhow to prevent blotching. But for lighter woods like maple, ash, sycamore , yew, etc, WOW! Several more coats to go, it's just beginning to 'build'. Pure linseed oil and beeswax, created by an enthusiast, fellow named Robson, available only at places like Woodcraft and Garrett Wade. Get some.
Thanks for the info [message #36838 is a reply to message #36837] Tue, 11 June 2002 19:18 Go to previous messageGo to next message
mikebake is currently offline  mikebake
BTW, did I gather correctly that you are in Mansfield? If you are free Wed July 3rd, buzz over for our party! Beer, band, BBQ chix, public fireworks display at the school a block away......you'd like it!
Re: Absolutely amazing wood finish [message #36839 is a reply to message #36837] Tue, 11 June 2002 20:41 Go to previous messageGo to next message
RJW is currently offline  RJW
Boiled or the other? No turpentine? Sounds nice, I know it smells good.
Ron
Man, it's good to have your experience here! [message #36843 is a reply to message #36837] Tue, 11 June 2002 23:30 Go to previous messageGo to next message
Thanks for the advice, Bill!
I've started buying old tube radios and restoring them, and the electronics are no problem for me but the woodworking leaves me "all thumbs." So I often take the advice of yours and other woodworkers on projects such as these. My last 1934 Montgomery Ward AM/shortwave "Airline" radio looks just great, thanks to advice from my woodworking buddies like you.
Did you say Chix? [message #36844 is a reply to message #36838] Wed, 12 June 2002 04:37 Go to previous messageGo to next message
Till likes Chix!
Whooaaa.....cool............... [message #36846 is a reply to message #36844] Wed, 12 June 2002 06:01 Go to previous messageGo to next message
We need them for our next Lima meeting..............can I get an amen?
Amen! [message #36855 is a reply to message #36846] Wed, 12 June 2002 16:01 Go to previous messageGo to next message
That's what I'm talkin' about!
Re: Absolutely amazing wood finish [message #36978 is a reply to message #36837] Wed, 19 June 2002 06:30 Go to previous message
walter H is currently offline  walter H
Dear Till E.,
I have a few questions about the 'tried and true orginal wood finish'.
1. Should it be used on non treated wood like maple muliplex
2. If you use the varnish, are you able to make the multiplex absolutely smooth (no feeling of wood any more)
3. Can you use additional lacquer it after this treatment
4. Does it really get dark after a few treatments, i.e maple becomes medium oak, or does it only makes the tan of the original wood deeper.
5. how large an area can be done with one can of wood finish.
I hope you respond. Thanks.
Walter
Previous Topic: What are you using for amplification?
Next Topic: If my calculations are correct.....
Current Time: Fri Nov 06 01:17:01 CST 2026
