Home » Sponsored » Pi Speakers » Studio 2 Pi cabinet construction questions
Studio 2 Pi cabinet construction questions [message #36814] Sun, 09 June 2002 05:11 Go to next message
Edwin is currently offline  Edwin
To Wayne and the rest of the guys,
I found a cabinet maker who will make the cabinets for me. I opted for mahogany. In line of this, I have the following questions:
1. As this is my first time in speaker building will I have any problems installing damping materials, drivers, wirings etc. in a finished cabinet? Or do I have to install everything inside before I close the back?
2. Does the Studio 2 Pi require bracings? If so, how?
3. What is the size of the connector panel hole? Is the 2.875" wide X 2.175" tall true for all connector panels included in the kit?
4. Also will changing my dimensions to 30.5" X 14" X 8", which has the same volume of 1.36 cu.ft. compared with the original dimension of 22" X 15" X 10" pose a problem?
5. Other suggestions or modification
Thank you for your patience in answering a newbie like me. I hope to build a 4Pi if this initial project succeeds :-)
Edwin
Re: Studio 2 Pi cabinet construction answers [message #36818 is a reply to message #36814] Sun, 09 June 2002 13:39 Go to previous messageGo to next message
I prefer MDF or baltic birch to solid wood. You can veneer it with whatever you like. Unless you can model the cabinet or test it, it is usually best to avoid having all dimensions the same or multiples. This prevents standing waves from aligning along more than one axis. Also, when I build speakers, I glue all the panels rather than making the rear panel removable. I install all the components, crossover, acoustic insulation, etc. through the woofer hole. I generally brace any cabinet that is larger than about 2 feet in any dimension with cross-braces every 18".
Re: MDF better than mahogany [message #36820 is a reply to message #36818] Sun, 09 June 2002 17:45 Go to previous messageGo to next message
I've never known you to offer an opinion that wasn't backed by science and I'm very curious to know about what probably amounts to MDF vs. most any solid hardwood? I don't really have an opinion one way or another but I do believe that my solid maple shelves have an influence on the sound of my CD player.
Another issue you touched upon, cabinet size: are low frequencies not concerned with standing waves? You see a lot of sub-woofer designs of 18X18X18 and 24X24X24, etc. My P'itanic is 22.5 cubed.
I don't hear any particular note boom and distortion seems very low. Why is that?
Re: MDF better than mahogany [message #36821 is a reply to message #36820] Sun, 09 June 2002 17:50 Go to previous messageGo to next message
I'm not sure about your other questions, I guess I'll let Wayne cover that, but as far as standing waves go, they only happen at higher frequencies.
Standing waves will begin to occur at the frequency whose wavelength is equal to the longest dimension of your box. So in your case, 22.5", which is a frequency of 603 Hz. Obviously well above your crossover point, so you don't have to worry about them!
Standing waves only become a problem when the speaker is playing frequencies which are close to or above this threshold. So they will only be a problem with woofers running up to high frequencies or woofer enclosures that are absolutely humongous.
Adam
Standing waves and resonance [message #36822 is a reply to message #36821] Sun, 09 June 2002 19:00 Go to previous message
The reason that particle boards and laminates are preferred for building loudspeakers is that they have several different fibers that are oriented in different directions. So the cabinet panels are less prone to resonance.
About subs, Adam was right. Standing waves are as much an issue for subs as anything else, but they are used at frequencies where wavelength scale is measured in feet. If your cabinet were several feet across then standing waves might set up but when crossed over in the double digits, small cabinets like you've described are nowhere near large enough for modal behavior to occur.
Previous Topic: Acoustic Filters, Waveguides and Transmission Lines
Next Topic: more questions! :-)
Current Time: Wed Oct 21 05:13:54 CDT 2026
