Home » Sponsored » Pi Speakers » Theater 3 or 4
Re: Theater 3 or 4 [message #36676 is a reply to message #36675] Mon, 27 May 2002 15:37 Go to previous message
Yes, the speakers should be pushed up against the back wall, within a few inches of it. It is nice if it is non-reflective, but the directionality of the speakers helps reduce early reflections off the back wall anyway.
About your amplifier, these speakers will probably work very well for you, even if your amp has only moderate damping ability. Most push-pull amps have some negative feedback and low output impedance, so they tend to not be as affected by speaker loads. If your amplifier has high damping ability, all reasonably high efficiency speakers will work pretty well on it. And with 10 watts, it probably has pretty good damping.
I suggest you speak with the manufacturer of the amplifier about its performance. If the output transformer has low enough output impedance, it may be that it will work well with practically any loudspeaker. So ask the manufacturer about the damping factor of your amplifier and whether it has specific loading requirements.
Previous Topic: 2 Pi Studio Plans
Next Topic: Sound characteristics of different horn flares and materials
Current Time: Thu Nov 05 06:42:11 CST 2026
