| Theater 3 or 4 [message #36646] |
Sat, 25 May 2002 14:10  |
SteveP
Messages: 2 Registered: May 2009
Esquire |
Two questions: 1) I noted from the pictures of completed speakers that most pi spkrs are placed close to the back wall. Is that how they sound best? Do you get better soundstage by moving them out from the walls? 2)I like the sound of the Cornwalls (especially the old Cornwalls) and was wondering if the Theater 3 or 4 is faily close in sound and maybe a short description. Also, would it be possible to get the cabinet plans for the 3 and 4? Thank you
| Re: Theater 3 or 4 [message #36675 is a reply to message #36652] |
Mon, 27 May 2002 14:45   |
SteveP
Esquire |
Hi Wayne, >> π Speakers are best in quarter-space or eighth-space, i.e. on the floor against walls or in corners. You mean the back wall?? How is the 4pi for med pwr push pull (ST70)? That is currently what I use, but may change up the road, but still probably at least 10W and P-P. In that case, would the 4pi be good? Thanks, Steve
| Re: Theater 3 or 4 [message #36676 is a reply to message #36675] |
Mon, 27 May 2002 15:37  |
Messages: 19105 Registered: January 2001
Yes, the speakers should be pushed up against the back wall, within a few inches of it. It is nice if it is non-reflective, but the directionality of the speakers helps reduce early reflections off the back wall anyway. About your amplifier, these speakers will probably work very well for you, even if your amp has only moderate damping ability. Most push-pull amps have some negative feedback and low output impedance, so they tend to not be as affected by speaker loads. If your amplifier has high damping ability, all reasonably high efficiency speakers will work pretty well on it. And with 10 watts, it probably has pretty good damping. I suggest you speak with the manufacturer of the amplifier about its performance. If the output transformer has low enough output impedance, it may be that it will work well with practically any loudspeaker. So ask the manufacturer about the damping factor of your amplifier and whether it has specific loading requirements.
