Re: Eminence H290 [message #36627 is a reply to message #36623] |
Fri, 24 May 2002 18:40 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Adam
Messages: 419 Registered: May 2009
Illuminati (1st Degree) |
Sorry for the confusion. The driver is only going down to 1kHz, but I'd like to keep the flare lower then that. Adam
Re: Good lense for the JBL 2426H [message #36629 is a reply to message #36618] |
Fri, 24 May 2002 18:59 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
ToFo
Messages: 219 Registered: May 2009
Master |
Adam, When I first got these things I mounted some Renkus Heinz Mid drivers to them to see how low they would go, and I can say they will make the bones in your ears click @ 800 Hz. I also got meaningful output from the psd 2002 @ 1000 Hz. I know I shouldn't have, but it was too tempting and easy with electronic x-over. 2002's sound lousy that low btw. It is a good clone of the 2370. Unfortunately the links below do not offer much info, but will allow you a source should you choose to try them. If you can see them at a shop next to a real JBL you will buy them. Without the logo I would not have been able to tell you the difference. The flare, support ribs, and all. I don't know how they got their dies, but they did an amazing job if they didn't steal them. I wonder if they have some kind of deal with JBL because they make replicas of most of their horns.Loudspeakers plus has a # you can call for technical info at the bottom of the page http://www.loudspeakersplus.com/html/ph2370-specs.html http://www.speakercity.com/paudio/HornIndex.shtml
