Home » Sponsored » Pi Speakers » Good lense for the JBL 2426H
Re: Eminence H290 [message #36627 is a reply to message #36623] Fri, 24 May 2002 18:40 Go to previous messageGo to next message
Sorry for the confusion. The driver is only going down to 1kHz, but I'd like to keep the flare lower then that.
Adam
Re: Good lense for the JBL 2426H [message #36629 is a reply to message #36618] Fri, 24 May 2002 18:59 Go to previous messageGo to next message
Adam,
When I first got these things I mounted some Renkus Heinz Mid drivers to them to see how low they would go, and I can say they will make the bones in your ears click @ 800 Hz. I also got meaningful output from the psd 2002 @ 1000 Hz. I know I shouldn't have, but it was too tempting and easy with electronic x-over. 2002's sound lousy that low btw. It is a good clone of the 2370. Unfortunately the links below do not offer much info, but will allow you a source should you choose to try them. If you can see them at a shop next to a real JBL you will buy them. Without the logo I would not have been able to tell you the difference. The flare, support ribs, and all. I don't know how they got their dies, but they did an amazing job if they didn't steal them. I wonder if they have some kind of deal with JBL because they make replicas of most of their horns.
Loudspeakers plus has a # you can call for technical info at the bottom of the page
http://www.loudspeakersplus.com/html/ph2370-specs.html
http://www.speakercity.com/paudio/HornIndex.shtml
Re: Good lense for the JBL 2426H [message #36630 is a reply to message #36629] Fri, 24 May 2002 19:07 Go to previous messageGo to next message
Those lenses look just about perfect for my application.
Thanks ToFo!
Adam
Re: Good lense for the JBL 2426H [message #36631 is a reply to message #36630] Fri, 24 May 2002 19:16 Go to previous message
let me know how it works out.
Thomas
Previous Topic: question about thermionic 3 plans and bracing
Next Topic: Pi Pictures
Current Time: Sat Nov 14 13:58:48 CST 2026
