Home » Sponsored » Pi Speakers » Good lense for the JBL 2426H
Good lense for the JBL 2426H [message #36611] Fri, 24 May 2002 12:09 Go to next message
Hey guys, what is a good horn lense for the JBL 2426H operating down to 1 kHz? I'm considering the JBL 2370A but it is simply way too expensive.
So any suggestions? It is a 1" bolt on and I'm using it down to 1kHz.
Adam
Re: Good lense for the JBL 2426H [message #36612 is a reply to message #36611] Fri, 24 May 2002 12:53 Go to previous messageGo to next message
Adam,
I am now using a copy of the 2370A made by P Speakers, a lot of pro shops use this brand. I do not have a 2426H on it, but it sounds great with the PSD 2002. I would love to have some JBL's though. The only difference I could see was the die seems were a little rough at the back of the throat. I used a small piece of 240 grit sandpaper to smooth it out. Now you can't tell the difference between the two. (I inspeacted them with a 2370 at the shop I bought them at) I paid about $82.00 each.
Follow the link and you will see that they are dead ringers.
Thomas
Or buy mine [message #36613 is a reply to message #36611] Fri, 24 May 2002 12:59 Go to previous messageGo to next message
mikebake is currently offline  mikebake
on ebay. They are in great shape, I hate to part with them, but........I figure if they get around $80-90n apiece I'll let 'em fly.
MBB
Re: Eminence H290 [message #36615 is a reply to message #36611] Fri, 24 May 2002 14:11 Go to previous messageGo to next message
they are the least expensive of any of the brand names. Parts express also carries some no name lenses but so far everyone is still wondering and not tried them. The peavey is a screw on and cost more.
bill
Re: Or buy mine [message #36617 is a reply to message #36613] Fri, 24 May 2002 15:09 Go to previous messageGo to next message
Thanks Mike, but I need eight of them.
If I buy your two, I'm committed to buying six more at their rediculous price.
Adam
Re: Good lense for the JBL 2426H [message #36618 is a reply to message #36612] Fri, 24 May 2002 15:13 Go to previous messageGo to next message
Hey, thanks Tom.
Do you have a website or anything like that where I can examine these things? I believe your word, but I'm taking the CD's down to 1 kHz, whereas the 2002's are only down to 1.5. I have to make sure the lenses will handle this well.
Also, are these the same flare type as the CH-3?
Adam
Re: Eminence H290 [message #36619 is a reply to message #36615] Fri, 24 May 2002 15:19 Go to previous messageGo to next message
I'd like to keep the flare frequency in the 600-800 Hz range. I have to run the unit down to 1,000 Hz.
Adam
Re: Eminence H290 [message #36623 is a reply to message #36619] Fri, 24 May 2002 17:17 Go to previous messageGo to next message
sorry, I thought you asked for a 1Khz not an 800
There's always something nice [message #36625 is a reply to message #36617] Fri, 24 May 2002 18:29 Go to previous messageGo to next message
about owning the real deal......
Re: There's always something nice [message #36626 is a reply to message #36625] Fri, 24 May 2002 18:39 Go to previous messageGo to previous message
Yeah... At the price of $1,800 dollars canadian :(
Adam
Previous Topic: question about thermionic 3 plans and bracing
Next Topic: Pi Pictures
Current Time: Mon Oct 05 18:28:35 CDT 2026
