Home » Sponsored » Pi Speakers » Reverse attenuation and HF comp. networks, active X-over
Re: Reverse attenuation and HF comp. networks, active X-over [message #36604 is a reply to message #36598] Thu, 23 May 2002 23:01 Go to previous message
Adjust the Q of the high-pass filter, which would then allow you to adjust peaking slightly above 0.707, to around 1.0. Add a voltage divider with bypass capacitance. Then you'll be able to set the filter Q for a flat shelf followed by rising response.
Previous Topic: Mr. Parham
Next Topic: Lathe turned horn for PSD2002
Current Time: Sun Nov 08 04:01:01 CST 2026
