Home » Sponsored » Pi Speakers » Reverse attenuation and HF comp. networks, active X-over
Re: Reverse attenuation and HF comp. networks, active X-over [message #36598 is a reply to message #36576] Thu, 23 May 2002 16:50 Go to previous messageGo to previous message
Hi Wayne,
Maybe I wasn't clear. What I'm using to divide the frequencies
are 18dB VCVS (Sallen-Key) filter stages. To control horn attenuation,
I'm putting a balance pot circuit between the inputs for
high/low (verses left/right). I was planning on putting the
HF comp between the output of the balance buffer and the input
of the HP filter. But now you're going to make me install spice
or write a perl script to verify what you are saying. Seems to
me that at freqs below 1/(2*Pi*Rs*C) (there's that Pi thing again :^),
the divider will work more like a divider because Xc will be > Rs.
Above that freq, the Xc will be less than Rs, hence provide HF
boost. It looks a lot like the one used in your x-overs. Wonder
where I got the idea. )^:
Rs
acsii art time: --\/\/\/\/\------
|___||_____| |
C #
# Rp
I got the filter circuits from an old Walter Jung OpAmp Apps book
from when I was in school. Gee, I know the formulas are close,
but I'll have to look them up AGAIN!
Thx, Chris
Previous Topic: Mr. Parham
Next Topic: Lathe turned horn for PSD2002
Current Time: Sun Nov 08 04:01:11 CST 2026
