Home » Sponsored » Pi Speakers » Lathe turned horn for PSD2002
Re: Lathe turned horn for PSD2002 [message #36592 is a reply to message #36585] Thu, 23 May 2002 10:13 Go to previous messageGo to previous message
str8aro is currently offline  str8aro
Just be careful if that's a wood lathe you're talking about. The headstock bearings might be much more robust in a metal lathe. Don't you usually use a tailstock when turning wood? Doing the horns, you won't have that support. I suppose you could turn the outside diameter using a tailstock center and then put a center rest on the mouth of the horn...
Previous Topic: Reverse attenuation and HF comp. networks, active X-over
Next Topic: For Sale: Eminence Kappa/2002 2-way speakers
Current Time: Sat Sep 12 04:45:10 CDT 2026
