Home » Sponsored » Pi Speakers » any tips on cutting baffle circles?
the driver and horn flanges cover the cutouts [message #36532 is a reply to message #36530] Mon, 20 May 2002 05:55 Go to previous messageGo to previous message
but you must avoid the temptation to cut the openings slightly too large, as there is very little "meat" left to attach your t-nuts into.
If you rent a saw, it might be a good idea to practice following a curved line some before cutting the baffles. Goggles and good lighting are a must, a means to secure the workpiece from moving also helps, clamp it down. Buy a quality fine tooth, hollow ground blade, but not the real narrow scroll kind, they can flex sideways while cutting.
Start watching the sale ads, memorial day is right around the corner...maybe a jigsaw "purchase" rather than "rental" would be cheaper in the long run.
Convince the wife you needed it for "artistic self-expression" by cutting out a random scrap of wood, stapling her picture to it (with your new stapler!), and varnishing over it. Hang her on the workshop wall. Works as good as jewelry once in a while. Then on fathers day, she will be more likely to buy you that finishing sander you will be needing... Sam
Previous Topic: Question for Wayne
Next Topic: Chicago Horns Summer Bash
Current Time: Fri Nov 06 03:30:12 CST 2026
