Which Pi Speakers work well at low/medium volume [message #36513] |
Sat, 18 May 2002 15:19 ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Peter Jay
Messages: 3 Registered: May 2009
Esquire |
I am considering building a set of studio 2Pi, Thermionic 3Pi, or Theater 4Pi to go with tube amps of PP (up to 40 watts) or SET design. Which of these speakers will play well at lower volume levels? Can't always crank it up in the living room. I haven't decided on an amp yet, so suggestions on appropriate matches between speakers and amps (kits preferred) would be appreciated. Just getting into tubes. Thanks in advance.
Re: Which Pi Speakers work well at low/medium volume [message #36527 is a reply to message #36522] |
Sun, 19 May 2002 06:29 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Garland
Messages: 269 Registered: May 2009
Grand Master |
Hi Peter, I just wanted to comment that one of the best aspects I've experienced with my Theater 4's is their ability to play at both high and low volumes and maintain a pleasing dynamic and tonal quality. They are the first speakers which I've owned that do this so well. So I can recommend the Theater 4 Pi if you want this ability to sound good at lower levels. I am driving mine with 3.5 watts of 2A3 power and can easily get over 100dB's if I want and suffer little distortion, but low, "after bed-time" levels, are still amazingly real sounding! I'm in the process of helping a friend build a pair of 2 Pi's and will report on how they perform as soon as they're done! (Assuming he'll let me borrow them!!!) G.
