Home » Sponsored » Pi Speakers » Which Pi Speakers work well at low/medium volume
Which Pi Speakers work well at low/medium volume [message #36513] Sat, 18 May 2002 15:19 Go to next message
Peter Jay is currently offline  Peter Jay
I am considering building a set of studio 2Pi, Thermionic 3Pi, or Theater 4Pi to go with tube amps of PP (up to 40 watts) or SET design. Which of these speakers will play well at lower volume levels? Can't always crank it up in the living room. I haven't decided on an amp yet, so suggestions on appropriate matches between speakers and amps (kits preferred) would be appreciated. Just getting into tubes. Thanks in advance.
Re: Which Pi Speakers work well at low/medium volume [message #36519 is a reply to message #36513] Sat, 18 May 2002 18:47 Go to previous messageGo to next message
Each of those will work very nicely for you.
Re: Which Pi Speakers work well at low/medium volume [message #36522 is a reply to message #36519] Sat, 18 May 2002 19:15 Go to previous messageGo to next message
Thanks, Wayne. I now have it down to the Thermionic 3 Pi or the Theatre 4 Pi. Is the 4 Pi better at lower volume levels than the three Pi because it is more efficient? Fewer watts required to reach a given sound pressure level, or is there not that much difference?
Re: Which Pi Speakers work well at low/medium volume [message #36523 is a reply to message #36522] Sat, 18 May 2002 19:43 Go to previous messageGo to next message
There's not a lot of difference with respect to your amp, the amount of sound and suitability for use at low listening levels. But your room may make a difference. If you plan to use these speakers in corners or against the wall, I'd suggest using the Theater four π speakers. On the other hand, if these will be pulled away from the walls or out in the open, then you might like the Thermionic three π speakers better.
Re: Which Pi Speakers work well at low/medium volume [message #36527 is a reply to message #36522] Sun, 19 May 2002 06:29 Go to previous messageGo to next message
Hi Peter,
I just wanted to comment that one of the best aspects I've experienced with my Theater 4's is their ability to play at both high and low volumes and maintain a pleasing dynamic and tonal quality. They are the first speakers which I've owned that do this so well. So I can recommend the Theater 4 Pi if you want this ability to sound good at lower levels. I am driving mine with 3.5 watts of 2A3 power and can easily get over 100dB's if I want and suffer little distortion, but low, "after bed-time" levels, are still amazingly real sounding!
I'm in the process of helping a friend build a pair of 2 Pi's and will report on how they perform as soon as they're done! (Assuming he'll let me borrow them!!!)
G.
Re: Which Pi Speakers work well at low/medium volume [message #36565 is a reply to message #36527] Tue, 21 May 2002 19:55 Go to previous message
Thanks, Garland. Just the info I was looking for. If you do get a chance to compare the 4 Pi's with the 2 Pi's I would like to hear your impressions.
Previous Topic: Chicago Horns Summer Bash
Next Topic: 2 Pi speaker questions
Current Time: Sun Oct 18 14:49:24 CDT 2026
