Home » Sponsored » Pi Speakers » What would you build with these JBL drivers and horns?
What would you build with these JBL drivers and horns? [message #36452] Thu, 16 May 2002 12:57 Go to next message
TimG is currently offline  TimG
(2) 2245H 18"
(2) 2226J 15"
(2) 2380A 2" throat horns
(2) 2440 2" throat compression drivers with 2441 diaphragms
(2) Fostex FT17H super tweeters
(2) M121-8 12" high efficiency wide range (similar to EVM12L)
(2) 2427H 1" or 2" compression drivers
(6) Klipsch 10" anodized aluminum shielded midbass drivers
Dude [message #36453 is a reply to message #36452] Thu, 16 May 2002 13:22 Go to previous messageGo to next message
mikebake is currently offline  mikebake
You can build all kinds of good stuff. 2 way, three way, 4 way, separate subs and mains, Pi speakers, Edgar-type system.........how about something like Drew Daniels system, see link
Re: What would you build with these JBL drivers and horns? [message #36454 is a reply to message #36452] Thu, 16 May 2002 13:23 Go to previous messageGo to next message
Robert Hamel is currently offline  Robert Hamel
Try this link it might give you some ideas. At the very least it is very interesting reading. Nice set of toys!
You read my mind look at the time on the posts!! LOL nt. [message #36455 is a reply to message #36453] Thu, 16 May 2002 13:24 Go to previous messageGo to next message
nt
I'd build an excellent, world-class system. That's what I'd do! [message #36459 is a reply to message #36452] Thu, 16 May 2002 15:14 Go to previous messageGo to next message
Re: I'd build an excellent, world-class system. That's what I'd do! [message #36460 is a reply to message #36459] Thu, 16 May 2002 15:30 Go to previous messageGo to next message
He could always try building my super 40 Hz horn design... :D
http://enclave.hypermart.net/bird/P0007604.JPG
http://enclave.hypermart.net/bird/P0007605.JPG
It would actually be perfect for the 2226's...
Adam
You can get a 16 Ohm version of the 2123 mid-range [message #36483 is a reply to message #36453] Fri, 17 May 2002 06:22 Go to previous messageGo to next message
KevinP is currently offline  KevinP
At the JBL Tent sale for $260/pr shipped. I'm thinking of picking up a pair for experimenting with a 300Hz-1200Hz use. I don't have a source for the 2012H but I would bet it is MUCH more expensive than what you can get the 2123 for at the JBL Tent Sale.
Re: You can get a 16 Ohm version of the 2123 mid-range [message #36499 is a reply to message #36483] Fri, 17 May 2002 17:18 Go to previous messageGo to next message
JohnR is currently offline  JohnR
Also, the 2123 seems a bit easier to work with, the FR is flatter up top (from the JBL spec sheets anyway)
JohnR
I don't know why that falling response is desirable. [message #36529 is a reply to message #36499] Mon, 20 May 2002 04:47 Go to previous message
But there seems to be a lot of drivers that have that characteristic. My guess is that using them in a horn to bring up part of the response would be part of their intended use. I don't really know... maybe Wayne can comment.
The older driver has better efficiency also... just by a smidgen. The newer 2012 is supposed to be lower distortion but I suspect they are both so low over the their frequency range that the parts would be identical for all practical purposes.
Previous Topic: Please "light trough" RCF motors
Next Topic: 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT?
Current Time: Fri Nov 13 07:03:03 CST 2026
