Home » Sponsored » Pi Speakers » Horn lens causing 1k bump?
Horn lens causing 1k bump? [message #36476] Thu, 16 May 2002 21:50 Go to previous message
RyanH is currently offline  RyanH
I just got my Selenium D205ti comp drivers and my on sale PE horns (sorry dont have the # right now, but they are the cast sale ones similar to the h290) and did a quick measurement. I screwed the driver to the horn and faced them up on the carpet, towards the ceiling (8 ft). I then held the mic overhead and took the measurement. I tried this on my other computer too with the same mic, but used a stand for it and still got the same thing: a hump cenetered at about 1.1 kHz. This is not evident in the Selenium literature (where its mounted on a diff horn), but the 6k dip is still there. I was wondering if this hump could be from the horn lens itself. I havent tested a driver sans horn, but if you guys think I should I will. Here's my measurement, it came out the same pretty much no matter what I did.
--Ryan
Previous Topic: 4Pi WIDTH, ROOM BOOST AND PORT PLACEMENT?
Next Topic: I lost my screws! (out of my compression drivers....)
Current Time: Thu Nov 19 11:22:02 CST 2026
