Home » Sponsored » Pi Speakers » What are the effects of cabinet volume on sensitivity??
What are the effects of cabinet volume on sensitivity?? [message #36447] Thu, 16 May 2002 08:54 Go to next message
Robert Hamel is currently offline  Robert Hamel
I have been measuring the sensitivity of my home builts and they are lower than I expected them to be. I am using a 10" in a small volume sub enclosure. Can the loading of the subenclosure raise the sensitivity of the midrange driver and can the box size effect the woofer???
Re: What are the effects of cabinet volume on sensitivity?? [message #36450 is a reply to message #36447] Thu, 16 May 2002 11:01 Go to previous messageGo to next message
Neither vented or sealed boxes raise the average efficiency of the driver. An underdamped alignment will increase bass output over a narrow range, but that creates a peak that is generally undesireable. The main objective of the cabinet is to provde a nice, flat response curve down to the cutoff point.
Thanks Wayne that's what I thought. Hey Sam P. 2035 users. [message #36461 is a reply to message #36450] Thu, 16 May 2002 15:34 Go to previous messageGo to next message
A little off topic but Help!! I am running 2035's and using L/R at 250hz. What is really strange is I am only getting about 93/94 db out of them in that passband????? That is very contrary to the numbers Sam P posted about them. I know a L/R is 6db down at crossover but I should be seeing a spike from say 40-150 Hz and its not there???
What's up??? Are the slopes on a L/R much broader than I think they are?? Can't seem to find a graph to see what the story is 1/2 octave from X-over. Jbl rates sensitivty from 100 to 500hz so I am at the edge of this band and the drivers don't get active in their midband.
But it seems strange,they are 4-5 db down from published numbers.
Or is it just the way I am using them? Everthing is up finished and working. They sound very nice but this really puzzles me.
Thanks Rob
Measurement tolerance [message #36463 is a reply to message #36461] Thu, 16 May 2002 15:50 Go to previous messageGo to next message
How and where did you measure these? Was it done in half-space outdoors, maybe on the ground pointed up? What measuring system did you use? I ask all these things, because there are a lot of places for ambiguity to creep in. If measured indoors, you can expect 6dB difference in average output just from moving speakers around in the room. I suggest a fairly good amount of tolerance should be considered if consistent references and calibrations aren't in place.
Good point they are relative to other speakers. [message #36473 is a reply to message #36463] Thu, 16 May 2002 20:09 Go to previous messageGo to next message
What I did was use an 87Db speaker as a reference with pink noise and then compared the level to the home builts which were 6db hotter. I used a speaker of higher sensitivity rated at 100db and it was 4db hotter so you are correct that the absolute is not right. 93 from the lower measuremant and 96 from the higher. That comes out to a 3db error between measurements. I am at 95 which gets me within a 3DB window if I split the two. You are good!!! I did not look at it that way before.
Thanks for your help.
some more 2035 data, and NEW jbl link [message #36480 is a reply to message #36461] Fri, 17 May 2002 05:03 Go to previous messageGo to next message
that appears to show what Robert is seeing. When I first was playing and testing, I hooked up the 2035's to my amp, no xover, just wired the v.c. direct. Input was 2.83 volts. (1 meter, on axis w/ the woofer I think)
100 100dB
150 99.5dB
200 98 dB
300 96 dB
400 98 dB
500 102dB
So there was a slight dip around 300Hz.
In box measurements after port tubes and stuffing and xovers resulted in slightly different results in this region. These were not measured at 2.83 volts, just started at 80dB/100Hz.
100 80dB 82dB
200 81dB 79dB
300 80dB 82dB
400 79dB 78dB
500 81dB 82dB
These were done at about 2 meters, mike in line between the "ears" and center of the baffle. Match between left and right would be hard to improve, this was measured "as listened to" in the room.
The last jbl info posted, detailing the 3677 system, calls the 2035 a 99dB driver. BTW, they use a 3rd order filter at 1.2kHz. with this woofer. I believe the SINGLE 2035 has close to, or slightly MORE output across the board than a PAIR of 2226J's(97dB per jbl).
Am I correct you are using the 2035's from 250Hz. AND DOWN. Below 80 Hz. they soon start their slow rolloff at the bottom. Raw data showed F10 at 60 or 70 Hz? Another issue you may want to consider, the z plot shows this driver is only 6 ohms at 200 Hz. By 100Hz, near 10 ohms. Peak at Fh(80Hz.) was 20.5ohms. Z at Fb was 6.3ohms around 48Hz. Not sure how that might be affecting your xover.
Like Wayne advised, in room measurements need to be taken with a grain of salt. You said they sound good, and that is the most important thing. Mine, in spite of the low end measurements, produce EXCESSIVE bass when I switch in EQ of +6dB@50Hz. Also, all measurements "in room" have my enclosures front baffle 3 feet in front of the rear wall...I am getting much less bass reinforcement from the walls.
That reminds me, the distance away from the wall I just mentioned can create a DIP in response when it is 1/2 wavelength, I'll try to find the reference url and post it later. Sam
in case anyone missed it, JBL has more tech data posted online at
www.jblproservice.com/support_info.htm
word of CAUTION, I saw the same xover schematic used in different systems whose HF drivers were different Z's, so verify component values to determine "if they make sense" before implementing the diagrams with "blind faith".
Thanks Sam!! [message #36484 is a reply to message #36480] Fri, 17 May 2002 06:30 Go to previous message
I know what you mean about the bass response. You are correct from 250hz and below. I have one very good position in my room I use for measurements. I have an idea from prevoius measurements on other speakers what the room is doing but like you said they are references and not absolutes. I always use another speaker as a reference tool from the same position in the room. I just swap them out to make the measurements. The driver spec. sheet calls it 98 and 2 give you 100db in the 4638??? So there are 3 diferent apparent ratings for the same driver?? We have 97 +3 in the 4638, 98 0n the driver sheet and 99 in the 3677. What I am getting appears flat just below what I expected. You are right if it sounds good "Don't worry about it"
Just trying to understand what is happening.
Previous Topic: Thermionic 3 vs. Theatre 4
Next Topic: JBL 2225's available (not mine)
Current Time: Sat Nov 28 18:54:09 CST 2026
