Home » Sponsored » Pi Speakers » mdf cabinet assembly question
Re: mdf cabinet assembly question [message #36444 is a reply to message #36440] Thu, 16 May 2002 07:43 Go to previous messageGo to previous message
On MDF I have had good success using butt joints and just glue - no screws. I like to assemble the front, sides, top and bottom all at once. It is a bit awkward and you will need some clamps. Using screws can help this - it eliminates the need for clamps. The reason I do it this way is that I get a better fit around the front baffle. Also, on MDF if your edges are a bit proud you can use a flush trimming bit on a router to just wiz them down to a nice flat finish with the other panels.
Steve
Previous Topic: good info site
Next Topic: Pi Speaker enclosure for Coaxial
Current Time: Fri Nov 06 02:10:14 CST 2026
