Home » Sponsored » Pi Speakers » mdf cabinet assembly question
mdf cabinet assembly question [message #36440] Thu, 16 May 2002 06:09 Go to previous message
ray99 is currently offline  ray99
Hi. After all pieces are cut, can anyone write a couple of sentences about the technique of how to glue all pieces together. I think I have to use butt joints because rabbet etc is over my head. Are the front and rear pieces glued to the edges of the sides or do they fit inside of the side pieces ? Do you glue one joint at a time or all pieces at once? Thank so much for your help. Ray.
Previous Topic: good info site
Next Topic: Pi Speaker enclosure for Coaxial
Current Time: Fri Nov 06 01:57:13 CST 2026
