Home » Sponsored » Pi Speakers » Another driver for 10Pi
Another driver for 10Pi [message #36303] Mon, 06 May 2002 09:45 Go to next message
Kim Schultz is currently offline  Kim Schultz
Hi,
I have looked around for another driver for the 10Pi, and came up with a wery promising alternative.
it's the Beyma 15K200, here are the specs:
fs 27 Hz
Re 6.3 ohms.
300 w RMS
Qms 9.01
Qes 0.27
Qts 0.26
98 dB, 2.83v @ 1m @
Frequency range 25-2000 Hz
Vas 345 l
Cms 320 µm/N
Net weight 10.4 kg. 22.92 lb.
Rms 2.76 kg/s
Magnetic assembly weight 9 kg. 19.84 lb
Efficiency, ho (%) 2.5
BL factor 20.5 N/A
Effective Surface Area, Sd(m2) 0.088 m2
Moving mass 0.106 kg.
Maximum Displacement, Xmax 7.5 mm.
Displacement Volume, Vd 660 cm.3
Voice coil length 21 mm.
Air gap height 9 mm.
Voice Coil Inductance, Le @ 1kHz 1.2 mH
X damage (peak to peak) 28 mm.
In JBL speakershop software, it has an f3 of 51,6Hz using a 87,6Liter
reflex with a (HxWxD)6" 3.5" 10" port.
I have tried to make it a close to the 10Pi as possible.
The JBL 2226 has an f3 of 74,3hz in the same cabinet.
It should work great, or what do you think ?
Regards
Kim
Re: Another driver for 10Pi [message #36307 is a reply to message #36303] Mon, 06 May 2002 11:02 Go to previous message
I think it is suitable, yes. But it may not be appropriate to use it in the exact same cabinet as the ten π folded horn used with the JBL 2226. Cabinet re-tuning might be in order, and possibly cabinet resizing as well. But it is certainly worth further inspection.
Previous Topic: Plans for Theater 7Pi's
Next Topic: Re: Klipsch horns
Current Time: Sat Nov 14 13:32:53 CST 2026
