Home » Sponsored » Pi Speakers » Using a JBL 2405 w/2" compression driver.
Using a JBL 2405 w/2" compression driver. [message #36299] Mon, 06 May 2002 07:01 Go to previous message
Kevin P is currently offline  Kevin P
Wayne,
Couldn't help myself and bought a 2445/2380 combination to use over my Kilomax 15". I was considering buying a pair of JBL 2405s to use on top and forgo the compensation. What kind of crossover do you recommend for integrating a 2405 with the 2445/2380?
Sensitivity is about 5db less for the 2405. My thoughts were to use a passive/active crossover system. I'd use two amps.... a couple big SS amps to drive the Kilomax with a 24db/octave point at the 800HZ point and a rumble filter built into the active system. I'd also have a active high-pass 800HZ point with 24db octave slope for the 2445s with a passive crossover for the 2445-2405 crossover. The amp used on the top end would be a 300B SET with 8 watts. My uncertainty is the best passive crossover to use with the 2405.
Thanks for all your advice.
Previous Topic: Ten Pi Info
Next Topic: Plans for Theater 7Pi's
Current Time: Fri Oct 23 23:25:19 CDT 2026
