Home » Sponsored » Pi Speakers » Pi designed bass for Oris horns?
Re: Pi designed bass for Oris horns? [message #36252 is a reply to message #36235] Fri, 03 May 2002 23:48 Go to previous messageGo to previous message
You wrote:
>> Could you recommend an amp to drive the Pi bass units?
I like Crown amps, lots of clean power. But there's a bunch of other amps that are suitable too.
>> Don't know the efficiency of any of these or how
>> they would cross over.
Obviously, this is application specific. But you could do it actively or passively without much difficulty.
>> How low would the 10 Pi option go down to?
A 2226-based ten π horn is strong down to 40Hz.
>> Where can I listen to one?
How far are you from Tulsa?
>> How much bigger to get down to 20 Hz?
Huge. I'd say horns that are useful to 20Hz would be for permanent installation only. You can make a reasonably sized reflex cabinet reach 20Hz, or you could make a transmission line, possibly a TL pseudo-horn. But a true basshorn that reaches 20Hz is a massive device.
Previous Topic: 10pi + fronthorn
Next Topic: My Oris/10Pi system
Current Time: Mon Nov 02 09:41:51 CST 2026
