Home » Sponsored » Pi Speakers » Oops.. too big!
per weems, you [message #36124 is a reply to message #36122] Sat, 27 April 2002 08:25 Go to previous messageGo to previous message
need to identify three freq.s using a z plot test setup. The lower peak is Fl, the upper peak is Fh, assuming a vented reflex enclosure. Then Fc, a single peak is found with the port sealed. Fb = sq.rt.[Fl^2+Fh^2-Fc^2] Fb is the box tuning of the whole system, after all is said and done.
A 'scope can also be used, the elipse will go into a flat line at Fb. Of course, your accuracy depend upon your sig gen calibration, that's life...but the sig gen cal can be verified against line freq (60Hz), so how far off will you be to either side...not much. Sam
Previous Topic: Computer crashed and burned!
Next Topic: Top octave compensation on non Eminence comp drivers
Current Time: Tue Oct 20 17:31:48 CDT 2026
