Home » Sponsored » Pi Speakers » Oops.. too big!
Oops.. too big! [message #36118] Sat, 27 April 2002 05:40 Go to next message
Remember that old saying, measure twice cut once.. good, no one has to rub my nose in it :-). So I somehow ended up making my 3pi Thermionic cabinets 400 cu in. too big. The external dimensions of mine end up giving a volume of 12070 cu.in. but the plans call for 10890 cu.in. When I account for the fact that I used 3/4 material and the plan uses 5/8 material, the inside volume difference is about 400 cu.in. The first question is, will this need to be corrected, is it a significant error? Second question is, righ now I'm about 3,400 cu.in. too small for a Theater 4pi. Would it be possible to add stuffing to bring up the volume and go that direction?
Thanks for the help!
Steve
Brace the heck out of them!!!(nt) [message #36119 is a reply to message #36118] Sat, 27 April 2002 06:37 Go to previous messageGo to next message
nt
based on my vast experience with 2 boxes:) [message #36121 is a reply to message #36118] Sat, 27 April 2002 07:56 Go to previous messageGo to next message
I would say "go for it"...if you use R13 to cover the entire rear wall, the bottom wall, and one side wall...my 2.5 cu.ft. "net Volume" boxes have consistently "tuned" as if the boxes were at least 3/4 cu.ft. larger than their actual physical size. Mine were acting like the "apparent volume after R13 stuffing" was increased by over 30%. Even after reducing the port tubes to half the original length, my tuning (50Hz) was still several Hz. lower than "Pi alignment specified". I recently removed a portion of the R13, and feel the tuning shifted a bit higher. Probably closer to 52Hz. Fb now. I had started with 1.2cu.ft. of R13 'glass inside the 2.5cu.ft. box...may have been overdamped...twin peaks (at Fl and Fh) were only 20 ohms. Sam
btw, go easy on the silicone seal holding the port tubes in...a beetch to pull loose from a 1/4 in. deep recess...and I'm pretty darn sure adjusting the length is often needed...only a careful z plot will tell you where you are for certain.
Re: based on my vast experience with 2 boxes:) [message #36122 is a reply to message #36121] Sat, 27 April 2002 08:12 Go to previous messageGo to next message
Sam,
how did you figure out the tuning of your enclosure?
Adam
per weems, you [message #36124 is a reply to message #36122] Sat, 27 April 2002 08:25 Go to previous messageGo to next message
need to identify three freq.s using a z plot test setup. The lower peak is Fl, the upper peak is Fh, assuming a vented reflex enclosure. Then Fc, a single peak is found with the port sealed. Fb = sq.rt.[Fl^2+Fh^2-Fc^2] Fb is the box tuning of the whole system, after all is said and done.
A 'scope can also be used, the elipse will go into a flat line at Fb. Of course, your accuracy depend upon your sig gen calibration, that's life...but the sig gen cal can be verified against line freq (60Hz), so how far off will you be to either side...not much. Sam
Cabinet and alignment tolerance [message #36134 is a reply to message #36118] Sat, 27 April 2002 11:49 Go to previous message
If you have only 400 cubic inch variance, you are well within tolerance. There will be no measurable difference, and certainly no audible difference. Change the size of the cabinet this much using a program like Boxplot to see what I mean. You can vary the size by a small amount or the tuning frequency and see its effects. You'll notice that this alignment is pretty tolerant of change, particularly when box volume is slightly increased.
Previous Topic: Computer crashed and burned!
Next Topic: Top octave compensation on non Eminence comp drivers
Current Time: Sat Nov 14 13:49:07 CST 2026
