Home » Sponsored » Pi Speakers » compression driver + 15 inch or large piezo horn + 15 inch
compression driver + 15 inch or large piezo horn + 15 inch [message #36082] Tue, 23 April 2002 13:31 Go to next message
Rudi is currently offline  Rudi
What is the difference between a 1 inch compression driver + 15 driver; and a piezo driver with a large horn[rectanglar horn].
Eminence Delta pro 15 300w rms bass driver + Eminence pds2002 1 inch compression driver 80w rms + Eminence pxb2-1k6 crossover.
OR
Eminence Delta pro 15 300w rms bass driver + Motorola ksn1140 piezo driver + CTS 15 inch x 5 inch exponential abs plastic horn.
Also I've seen some new Peavey 2 way cabinets featuring 4 ports.why would a normal 2 way design have 4 ports.I thought only bass bins or subwoofers have that many.
Large format piezo midrange/tweeters [message #36083 is a reply to message #36082] Tue, 23 April 2002 14:32 Go to previous messageGo to next message
I can't comment about large format piezo drivers. I don't use them. I use the KSN 1038, which is one of a family of devices introduced by Motorla for use above 3500Hz.
Re: compression driver + 15 inch or large piezo horn + 15 inch [message #36084 is a reply to message #36082] Tue, 23 April 2002 15:49 Go to previous messageGo to next message
Personally, I'd totally go with the compression driver.
Even larger sized piezos may only go down to 2 or 3 kHz with authority. This frequency is too high for a 15" woofer to run up to effectively. Go for the compression driver.
As far as the ports go, well how many 'ways' a system has has nothing to do with ports. A 2-way system simply means that the frequency band is split into two portions, each diverted to different speakers. So a 2-way system would have a woofer and a tweeter. A three way system would have a woofer, midrange and tweeter. Etc.
Adam
Re: compression driver + 15 inch or large piezo horn + 15 inch [message #36091 is a reply to message #36082] Tue, 23 April 2002 18:06 Go to previous message
mhammill is currently offline  mhammill
The ksn1188 piezo does go down to 700hz and is remarkably smooth with a 5x15 parts express horn but the efficiency is no match for a delta15. It's about 93db and a delta15 is more like 100db so it just won't keep up. But there are other 15" woofers that would work very well with this horn.
But no match for a theater 4pi.
Good luck.
Mike H.
Previous Topic: Theater series Four Pi
Next Topic: initial exponential horn design
Current Time: Thu Nov 05 12:05:14 CST 2026
