Home » Sponsored » Pi Speakers » Port size question
Port size question [message #36078] Tue, 23 April 2002 10:41 Go to next message
JLapaire is currently offline  JLapaire
I'm working on a pi-aligned box for some 12" Daytons and Pi-Align gives me a port size of 4.68" x 11" long. Is there a way to resize that to a standard 3" or 3.5" ID? I don't have room on the baffle for a rectangular port of 1/2" or 3/4" material.
Thanks very much in advance.
John
Re: Port size question [message #36079 is a reply to message #36078] Tue, 23 April 2002 10:44 Go to previous messageGo to next message
Try calcuating for a 4" diameter port, and then adjust the port length in the program until you get the same tuning as you do with the port you have there. It'll give you the Fb in the box parameters list.
Adam
Re: Port size question [message #36080 is a reply to message #36079] Tue, 23 April 2002 11:25 Go to previous message
Yessss, it worked! I put in 3.5 for the ID of some PVC electrical conduit I've got plenty of, and after a few tries came up with a length of 5.5".
Thanks for the help.
John
Previous Topic: stage series plans
Next Topic: Theater series Four Pi
Current Time: Fri Oct 02 10:03:25 CDT 2026
