Home » Sponsored » Pi Speakers » Theater series Four Pi
Re: Theater series Four Pi [message #36068 is a reply to message #36067] Mon, 22 April 2002 14:08 Go to previous messageGo to previous message
One thing that is very important for good sound on low-power SET amp is how the woofer acts at resonance. All speakers have an impedance peak when driven at their resonant frequency. This condition is also associated with back-EMF and amplifiers with lower damping factor are less able to control the motor; Particularly troublesome are those with greater impedance peaks, which are then creating more back-EMF.
When you put a speaker in a cabinet, it changes this peak and makes the speaker have a different impedance curve. Sealed cabinets tend to shift the peak up in frequency. Reflex cabinets create two peaks, both having less impedance than the single free-air peak. Horns and transmission lines create multiple peaks, generally lower in amplitude than the free-air peak, depending on flare shape and rear chamber.
Impedance fluxuations cause problems for tube amps, altering their response curve. The speaker impedance forms a voltage divider with the amp's output impedance, and if the ratio of impedances fluxuates, then the power transfer does too. So to make a long story short, if you have a small signal tube amp, you'll want to find a speaker with a low impedance peak at resonance, somtimes referred to as "Zmax."
Previous Topic: Port size question
Next Topic: compression driver + 15 inch or large piezo horn + 15 inch
Current Time: Fri Nov 06 10:32:36 CST 2026
