Home » Sponsored » Pi Speakers » 14ga solid copper wire? (for Wayne)
you can only tighten binding posts so much [message #36037 is a reply to message #36035] Fri, 19 April 2002 05:46 Go to previous message
but with pin connectors, and solid wire, any movement of the speaker cable will tend to allow the connection to loosen. Sure, you can get pliers and crank them tight enough. I feel a large gauge stranded cable, with many fine conductors, allows the wire to "crush" nicely when the binding post pressure is moderate. As Wayne said, stranded cable is more flexible, so movement won't strain the speaker wire/binding post connection. I think the mechanical concern of maintaining a tight and worry free connection precludes the use of large solid wire. Sam
Previous Topic: attenuating 1197 piezo
Next Topic: People using Paramours...
Current Time: Thu Nov 05 06:31:41 CST 2026
