Home » Sponsored » Pi Speakers » Wayne - Is this a WACKY idea?
Re: Wayne - Is this a WACKY idea? [message #36008 is a reply to message #36007] Wed, 17 April 2002 13:08 Go to previous messageGo to previous message
The problem with this is how the woofer would radiate the frequencies from the rear of the box. Even a 24" wide baffle begins the transformation at around 615 Hz. So imagine your woofer bouncing midrange frequencies around the back of the speaker, smearing the image and making for an incomplete compensation.
There is nothing wrong with your idea, it's called a 2.5 way setup, and you'll have to use a proper inductor to keep the frequency response in check at the higher frequencies. The only thing I would worry about that is the inductor not rolling frequencies off enough to eliminate breakup modes. The way to fix this is to just mount the woofer on the front of the box instead of the back. As far as pushpull goes, it may not be a good idea with your woofer running up to 600 Hz or even higher.
Adam
Previous Topic: Contemplation on combined Sensitivity(long)
Next Topic: Binding posts vs 1/4 inch jack vs XLR vs Speakon
Current Time: Tue Oct 20 14:56:25 CDT 2026
