Home » Sponsored » Pi Speakers » crossover design... help....
Re: crossover design... help.... [message #35974 is a reply to message #35973] Mon, 15 April 2002 11:40 Go to previous messageGo to previous message
Pilkar is currently offline  Pilkar
hi Wayne,
thank you very much for your reply... now, how do i know for which frecuency i should compensate? i must look at the response graph, don't i? if i place a l-pad to pad down the driver, the high octaves are padded as well? which data of the spec sheet i need to model the drivers in spice?
a last thing... i was looking at your designs... they are excellent but, will they work with my speakers? i mean, are they optimized for one of your designs or it is OK to use them with another speaker?
sorry... something else... it is too difficult wounding a coil myself? i have experience wounding transformers... is this much more difficult? do you know any program that can help me in this task, such as wire gauge, core diameter, number of turns, etc.?
well, thats all for now... thank you very much again!
Matias
Previous Topic: Horn flare survey
Next Topic: Folded horn subs--yuck!
Current Time: Thu Oct 15 00:08:37 CDT 2026
