Home » Sponsored » Pi Speakers » L-pad on LF driver
Mathematical models [message #35885 is a reply to message #35876] Mon, 08 April 2002 20:26 Go to previous messageGo to previous message
Have you used Spice? That will allow you to model the electrical circuit perfectly, and the acoustic filter functions are simple enough that they can be modeled on it if you choose to do so. Coming at it from the other direction, you can use Thiele/Small, adding any attenuation resistance you decided upon by manipulating Qes. And using David McBean's Hornresp, you can model the response of the basshorn with and without additional resistance in the woofer circuit simply by adding it to the motor's Re. So there are several ways to model the system - Some that focus mainly on the acoustic filter functions and others focusing primarily on the electrical filters. Each sort of "touches" on the other.
Previous Topic: Review of speakers?
Next Topic: would like plans...
Current Time: Wed Oct 21 00:56:40 CDT 2026
