Home » Sponsored » Pi Speakers » Need Plans
Need Plans [message #35883] Mon, 08 April 2002 20:09 Go to next message
Nashvilletitans is currently offline  Nashvilletitans
Could I please get a set of Theater 4 plans? Would very much like to build a set of these. Thanks
John
Or advice [message #35884 is a reply to message #35883] Mon, 08 April 2002 20:15 Go to previous messageGo to next message
Would the Thermionic Studio Series 4 be a better choice with an SET 8 watt 300b amp? Thanks again,
John
You have mail! [message #35886 is a reply to message #35883] Mon, 08 April 2002 20:37 Go to previous messageGo to next message
Thermionic or Theater 4 - An often asked question [message #35887 is a reply to message #35884] Mon, 08 April 2002 20:39 Go to previous messageGo to next message
The Theater Series four π Speaker is marginally more efficient, but the Thermionic four π goes a bit deeper. The Thermionics have a different damping value so they sound fuller, and the midrange takes on a slightly different character too, having a sound that I would describe as vintage tube sound. But they are very large.
Thanks Wayne [message #35888 is a reply to message #35883] Mon, 08 April 2002 21:02 Go to previous messageGo to next message
WOW, that was quick, thanks a million Wayne!
John
I'm curious [message #35907 is a reply to message #35887] Wed, 10 April 2002 09:18 Go to previous messageGo to next message
dbeardsl is currently offline  dbeardsl
You mentioned that the Thermionic Four Pi has a tiny bit more extension at the top end?
Whats different about em? They both use the 2002 right? Is there a little more top octave compensation?
I just ordered some plywood blades for the skilsaw, some 36" clamps, and a cutting guide/straight edge thingy. I'm set :-).
I'll take lots of pictures of course.
Re: I'm curious [message #35909 is a reply to message #35907] Wed, 10 April 2002 11:42 Go to previous message
That's right, exactly. The Thermionic uses the same PSD2002 tweeter but has a little more top-octave compensation.
Previous Topic: 600 hz crossovers
Next Topic: dynaudio frecuency response table
Current Time: Tue Oct 20 12:34:48 CDT 2026
