Home » Sponsored » Pi Speakers » HUGE PROBLEMS!
Re: Ground loop and impedance mismatch [message #35874 is a reply to message #35871] Mon, 08 April 2002 14:42 Go to previous messageGo to previous message
If there is a ground loop then the only way top solve your problem is to isolate the systems. Generally, the ground must be at the same potential, i.e. very little resistance between all ground reference points, or the two systems should be isolated. Isolation requires something like an opto-isolator or a transformer.
But since your setup is sort of a "get you by for now" solution, it really doesn't merit any real intensive work trying to solve. Put your energies into finding a way to get a better preamp connection method.
Previous Topic: Eminence beta 15
Next Topic: Plans for 4Pi
Current Time: Sat Oct 17 20:08:54 CDT 2026
