Home » Sponsored » Pi Speakers » Quick question
Quick question [message #35797] Wed, 03 April 2002 22:26 Go to next message
Erik from Holland is currently offline  Erik from Holland
Do i nead a Peavey CH3 horn-flare? I mean, is`nt there a eminence horn flare wich will work?
Ordering a horn-flare from Peavey is a bit of a problem.
Erik
Quick answer [message #35798 is a reply to message #35797] Thu, 04 April 2002 02:57 Go to previous message
The Eminence H290 horn flare will work perfectly well in all π Speakers designs using a 1" exit compression driver and a 1.6kHz crossover frequency. Don't try to use an H290 in other designs that run the tweeter much lower though because it's a 1kHz horn.
Previous Topic: Why not Kappa 15?
Next Topic: minimum width of cabinet on Three Pi reflex
Current Time: Fri Nov 06 00:38:16 CST 2026
