Home » Sponsored » Pi Speakers » Why not Kappa 15?
Why not Kappa 15? [message #35792] Wed, 03 April 2002 19:22 Go to next message
mhammill is currently offline  mhammill
Is there a reason why the Kappa 15 is not used in any Pi models, it looks promising? Is it too peaky?
Thanks
Mike H
Re: Why not Kappa 15? [message #35794 is a reply to message #35792] Wed, 03 April 2002 20:37 Go to previous messageGo to next message
I'm sure there is nothing wrong with the Kappa series. I just didn't feel the need to make so many speakers - There are several in my line already. Each "line" is double the power of the previous line. If efficiency is the same, doubling power is only a few decibels difference, so having lines less than double of each other makes for a lot of overlap in performance. My lines overlap pretty much as it is; To have a line every 100 watts would really be overkill in my opinion. That's the only reason I've skipped the Kappa series.
Re: Why not Kappa 15? [message #35795 is a reply to message #35794] Wed, 03 April 2002 20:38 Go to previous messageGo to next message
Yep.
My Pi's use Kappa drivers and they sound fine. Just a design decision on Wayne' part. Actually, I find the Kappas to be the best value in the Eminence line, IMO.
Adam
Re: Why not Kappa 15? [message #35796 is a reply to message #35794] Wed, 03 April 2002 21:15 Go to previous message
Erik from Holland is currently offline  Erik from Holland
Hi people,
So people seem to have a spare pair, so why not make a nice little list with modifications to the models, if using a other model from eminence or JBL.
Like the kappa or the new MAGNUM series.
and wayne,
I still can`t manage to plot the scheme from the 4Pi with Kappa LF.
But the LF is very much like the kappa, and i think it will work out well.
See you.
Previous Topic: A link for the tube people
Next Topic: Quick question
Current Time: Fri Nov 06 01:01:54 CST 2026
