Home » Sponsored » Pi Speakers » Foldes Bass Horn plans
Re: Foldes Bass Horn plans: Karlson design [message #35638 is a reply to message #35633] Fri, 22 March 2002 08:50 Go to previous messageGo to previous message
freddyi is currently offline  freddyi
Hi Shekhar,
Karlson box is an odd thing - look under 'articles' on Job Ulfmna's Karlson pages
the 'coupler" consists of a 65 liter tapered cross-section pipe with radial slot cut in side - the slot broadbands the front pipe resonance - orignal 1951-54 design has a 'shelf' board - think it acts as a short waveguide and possibly sets up a hybrid condition between rear chamber's port and 1/4 wave action - I'm currently running a variation without any shelf board - just tuned to ~39Hz Z min between first two peaks - need to tweak a bit - am getting ~2.5db over similar reflex with same driver @32hz and 3dB in upper bass
in typical 15" size Karlson, there's a 3rd Z max occuring around 160hz
initally years ago, I considered it a non-sensical design but after using find subjectively that they can outpoint a reflex on heavy transients - they tend to have some gain above 50Hz - it sounds "faster" than folded horn
by 1965 Karlson had decided ellipse based reflectors could improve the design - maybe so depending upon whether used high to reach horn or used as sub bewo 125Hz
Karlson is worth building to hear - think they do best with lower mass 15" having a good force factor - Altec 421 do well in 1954 specs
amazing you're assembling drivers to get what you need! - are there a couple of manufacturers in India who build high-end pro woofers, along lines of US Digital Designs' "Beast"?
Very Best!
Freddy
ps - hope this link is correct - couldn't load Karlson page to directly copy and paste
Previous Topic: Tempting fate... I booked a room...for the AudioFest...
Next Topic: cheap skate amp award?
Current Time: Mon Nov 02 12:25:31 CST 2026
