Home » Sponsored » Pi Speakers » Foldes Bass Horn plans
Foldes Bass Horn plans [message #35613] Thu, 21 March 2002 01:53 Go to next message
Shekhar is currently offline  Shekhar
Hi,
This is a great site and am happy to have come across it. Hope to build it better together.
I've been designing and making my own Bass horns for dance clubs and have usually used 15" folded horns but they rarely deliver anything useful below 55 Hz due to size limitations. So for a while i've been looking around for a solution which could give a lower usable freq limit (maybe a t the cost of a li'll efficiency loss). i have traditionally steered clear of 18" drivers for employment in any kinda bass (for dance and new age music reproduction) due to the poor transient response. But to my surprise i heard a set of four Cerwin Vega LR 36 18" subs recently and was surprised with their efficiency as well as the transient response.
I would appreciate if anyone can help me demystify these beautiful machines and or supply me with their plans (SL 36 and LR36B)
Regards,
Shekhar.
Re: Foldes Bass Horn plans [message #35616 is a reply to message #35613] Thu, 21 March 2002 05:36 Go to previous messageGo to next message
Walt is currently offline  Walt
Hello,
The reasons the LR-36 did work so well, was because they were stacked together. When you stack several 15" horns you will get the same effect. We have been using the CV-36A design (62x62x92cm) with RCF L18P300 woofers. We were not impressed at all... we were using one per side.
They can give a great sound but as I said, you need at least 4 a side to reach the 45Hz notes with full power.
If you want a small punchy cabinet at only one per side which goes DEEP, take a look at the Karlson design. These cabs can give you amazing results (when built correctly)
Best Regards,
Walt
Re: Foldes Bass Horn plans [message #35618 is a reply to message #35613] Thu, 21 March 2002 06:56 Go to previous messageGo to next message
freddyi is currently offline  freddyi
Greetings Shekhar,
as Walt says in his post below and as you know from experience, conventional basshorns built to 1/4 size or less will not give great low-frequency performance as they approach cutoff -- also they become bulky below 70Hz flare and more so when stacking in multiples - I've not heard the new C-V but assume they use a long-throw 18" like Digital Designs' "Beast"
a reflex has a better figure of merit in LF than horn for equivalent bulk and to my ears a Karlson with good driver and back plus tapers braced will outpunch both reflex and practical sized horns
Rog Morale presents several designs for 18", one with fairly long path but Walt and his brother Martjin built that and were disappointed compared to their Karlson boxes - My Karlson both stock and mod do better for solid sound below 100Hz than my Peavey FH-1 or Sentry IV - - more than mesurements,- Karlson 15" seem to excell on transients such as kickdrum and heavy bass - a approximately scaled 18" Karlson might be a winner for PA application - Cetic Gauss marketed one in 1970's - if you're in US then Eminence Sigma could be a nice 18" for low cost (~$125 discount) assuming its power handling is sufficent for your needs
Wayne's 10pi horn may well work better in LF.
Here's Rog Morale (horn/bandpass/scoop) and Job Ulfman's (Karlson) links:
http://www.speakerplans.com/index.html
http://studict.student.utwente.nl/e.j.j.ulfman/
Best wishes,
Freddy
Re: Foldes Bass Horn plans [message #35627 is a reply to message #35613] Thu, 21 March 2002 15:31 Go to previous messageGo to next message
I recently had some help designing an exponential horn for a JBL 15" (don't remember the model) which can fit in a 40 cubic foot cabinet in 1/4 space (against floor and a wall). 40 Hz flare.
BTW, if I were you I wouldn't be worried about 18" drivers and transient response... That's very much a myth. Some of the best drivers for SQ have been that size or even larger.
Adam
Re: Foldes Bass Horn plans [message #35632 is a reply to message #35618] Thu, 21 March 2002 23:40 Go to previous messageGo to next message
Greetings Freddy,
Thanks for your interest and taking time out. Your right when you say that a well designed reflex will outperform any practical sized folded horn, thats been my experience too but the reason i'm getting deeper into this whole (kinda endless :-) debate between folded horns and reflex designs is that I have a bit of this transient bug bothering me too much.
Regarding my choice of LF drivers less said the better, i'm in delhi India and the only drivers which have sustained availability and repair kits are the common ones from j.b.l. like 2226H etc. So i'm kinda very limited in my own right. Nevertheless Guess its been a blessing in disguise as due to above i've become adept to designing improvising and custom manufacturing my own LF drivers using a combination of my own basket assemblies and ready stock recone kits!!
Thanks once again for your input.
Best wishes and good luck,
Shekhar.
Re: Foldes Bass Horn plans: Karlson design [message #35633 is a reply to message #35616] Thu, 21 March 2002 23:58 Go to previous messageGo to next message
Hi Walt,
Thanks for your input on the same. About Karlson design, well I have'nt heard them ever and so am clueless about them. I will greately appreciate if you can help me with their detailed charecterstics and plans. Any light on the same will be much appreciated.
Good luck,
Regards,
Shekhar.
Re: Folded Bass Horn plans [message #35636 is a reply to message #35613] Fri, 22 March 2002 07:08 Go to previous messageGo to next message
The Cerwin Vega L36 and T36 basshorns are pretty good. They're small and inexpensive, and response is pretty good considering that. But the ten π basshorn is larger, so bass response is deeper and smoother. I've sent plans for the ten π basshorn to your E-Mail address.
Re: Foldes Bass Horn plans: Karlson design [message #35638 is a reply to message #35633] Fri, 22 March 2002 08:50 Go to previous messageGo to next message
Hi Shekhar,
Karlson box is an odd thing - look under 'articles' on Job Ulfmna's Karlson pages
the 'coupler" consists of a 65 liter tapered cross-section pipe with radial slot cut in side - the slot broadbands the front pipe resonance - orignal 1951-54 design has a 'shelf' board - think it acts as a short waveguide and possibly sets up a hybrid condition between rear chamber's port and 1/4 wave action - I'm currently running a variation without any shelf board - just tuned to ~39Hz Z min between first two peaks - need to tweak a bit - am getting ~2.5db over similar reflex with same driver @32hz and 3dB in upper bass
in typical 15" size Karlson, there's a 3rd Z max occuring around 160hz
initally years ago, I considered it a non-sensical design but after using find subjectively that they can outpoint a reflex on heavy transients - they tend to have some gain above 50Hz - it sounds "faster" than folded horn
by 1965 Karlson had decided ellipse based reflectors could improve the design - maybe so depending upon whether used high to reach horn or used as sub bewo 125Hz
Karlson is worth building to hear - think they do best with lower mass 15" having a good force factor - Altec 421 do well in 1954 specs
amazing you're assembling drivers to get what you need! - are there a couple of manufacturers in India who build high-end pro woofers, along lines of US Digital Designs' "Beast"?
Very Best!
Freddy
ps - hope this link is correct - couldn't load Karlson page to directly copy and paste
Re: Foldes Bass Horn plans: Karlson design [message #35660 is a reply to message #35638] Sat, 23 March 2002 00:18 Go to previous messageGo to next message
Hi Freddy,
Got the link to the site and have begun all the research I can do on the same :-) After listening your experience with Karlson designs I'm almost itching to finish one as soon. Regarding the original 1951-54 design are there any changes/tweaking that you suggest? Any light on the specifications of the ideal driver to be used with it?
Now talking about High end pro. speakers well, (i'm smiling even before you can read this :-) j.b.l cinema speaker drivers are as high end as they get here. Though a lot of stuff is available in the unorganised market here, almost anythingand everything. But the prices are crazy. To give you an idea, would u believe a j.b.l. 2226H for us$-440/450!! Unbelieveable...specially when you convert it into the currency here.
Phew!! nough' of that i've had....Glad i'm moving soon from here.
Have a good day!!
regards,
Shekhar.
Re: Foldes Bass Horn plans: Karlson design - heres radial slot calculator [message #35662 is a reply to message #35660] Sat, 23 March 2002 06:04 Go to previous message
Dear Shekhar -
you're doing better than me - messed-up (from virus) computer can't access the Karlson site
the enclosure is such an oddball - main changes were to tack wood strips on port and shelf gaps - wouldn't have to be glued to try - think this moves Z min from 50Hz t0 48Hz or so - also 1st specs had a bit more taper gap
despite exponential slot claim - I think Karlson used radial:
Compute the radius r as follows:
r = ( h^2 + w^2 - w*t + t^2 )/2*( w - t )
For Karlson 15, h = 30.19, w = 10.17, t = .23, r = 51
For Karlson 12, h = 23.5, w = 7.38, t = .25, r = 42.5
RADIAL SLOT CALCULATOR:
5 CLS
10 Print "This Routine Calculates a Karlson Radial slot"
20 Input "Enter height of slot";H
30 Input "Enter t=1/2 width at taper's start";T
40 Input "Enter w=1/2 width at taper’s end";W
50 R = (H^2+W^2-W*T^2)/(2*(W-T))
60 Print "Radius for this slot ="; R
at frequencies felow tuning the karlson will pretty much mesure with warble and sine like a 100l reflex tuned similar - above tuning, things aer different - do suspect distribution of power is pretty much affected by system tuning as tuning to 28hz gave waht you'd expect from a reflex plus lost a bit of uppser bass - sounded very good - for some reason sounded better than measurements indicated - this was eXemplar guys's sub for Altec A-7 - used a 30Hz bandpass on lo-tuned Karlson and 30Hz hi-pass on A7
will try to meet you on Karlson forum or High Efficiency forum so we won't eat so much of Wayne's bandwidth
probably just have to build and try some drivers you have - if you use a high crossover point then look for a driver which has riding on-axis response - EV15L was ok - liked Altec 421 better - had a big sound with 511 horn with Eminence 1" on top ~1.2Khz xover
Freddy
Previous Topic: Tempting fate... I booked a room...for the AudioFest...
Next Topic: cheap skate amp award?
Current Time: Fri Nov 13 06:38:26 CST 2026
