Home » Sponsored » Pi Speakers » cabinet maker screwed up again
cabinet maker screwed up again [message #35517] Sat, 16 March 2002 18:47 Go to next message
okay, my cabinet maker just dropped off my (lima demo's) premium stage 4 pi's. they look gorgeous finished in mahagony veneer. here's the problem, i gave him exterior dimemsions (based on 1" cabinets) but he made them in 3/4" and the port which was to be 10" in length is now 10 3/4" in length. so now my cabinet's have a little extra volume and the port is a 3/4" too long. will it matter? i plan on installing the drivers next week. wayne, i need your expert opinion.
cheers,
george
Re: cabinet maker screwed up again [message #35518 is a reply to message #35517] Sat, 16 March 2002 20:18 Go to previous messageGo to next message
On the volume - It's no problem. For one thing PiAlign tends towards smaller cabinets and volume tolerance is pretty large, and for another, we could always add displacement material inside if we found it to be out of tolerance too much. On the port - Can you remove 3/4" length? Does the cabinetmaker have tools that could easily remove this much material from them? They are pretty close to the rear and side of the cabinet, so it might be difficult. But the port dimensions require much tighter tolerance.
I honestly think that you're OK, and certainly this is true with the overall cabinet dimensions. You'll find that if you go one direction - towards overdamped - the bottom cutoff frequency strats to rise rapidly after a certain point. But until you reach that point, response doesn't hurt much by being a bit overdamped. And going the other direction, you'll reach a point where peaking starts to rise fast. Before that, you aren't going to have a bad response curve and can barely tell the difference and then suddenly, there's nothing you can do to remove the peak. So those two points - one towards the overdamped and the other towards underdamped - are what I'm talking about when I say "in tolerance." The window between these two events is pretty wide for PiAlign'ed cabinets. It's a very conservative alignment.
So that 1/4" is almost nothing, so as long as its braced sufficiently, you're in business. And I'll check the response curve for the port and double-check my assumption on the cabinet volume too.
I'll let you know by tomorrow afternoon.
Re: cabinet maker screwed up again [message #35519 is a reply to message #35518] Sat, 16 March 2002 20:53 Go to previous messageGo to next message
Yep.
If anything, I'd say it would even sound better. Larger cabinet, similar tuning... More deep bass.
Adam
Re: cabinet maker screwed up again [message #35520 is a reply to message #35519] Sat, 16 March 2002 21:06 Go to previous messageGo to next message
I think it will probably be alright too. The only thing I want to check is that it not slide off towards being underdamped, which would cause it to sound boomy. But I don't think the shift is all that great. The alignment has pretty wide tolerance, so the shift would have to be large to upset it.
Re: cabinet maker screwed up again [message #35525 is a reply to message #35517] Sun, 17 March 2002 05:45 Go to previous messageGo to next message
George
I can transport the drivers, if you would like to test the JBL 2226 in your new cabinets at Lima, Midwest Audiofest. I dont know if the hole and bolt up is a match or not.
Bill
BoxPlot shows minimal difference in response [message #35526 is a reply to message #35517] Sun, 17 March 2002 05:58 Go to previous messageGo to next message
I ran some simulations and you're going to be just fine. Response changes only imperceptively. In fact, you've got a pretty large window of 30Hz and 10 cubic feet to 45Hz and 2.5 cubic feet where response is linear.
So don't make any changes unless the port is too near the rear of the cabinet. As long as you've got a couple inches clearance, you'll have the same response with the dimensions you gave as with those specified in the plans.
Re: cabinet maker screwed up again [message #35531 is a reply to message #35525] Sun, 17 March 2002 08:37 Go to previous messageGo to next message
hi bill, i'm loading the cabinets with kilomax 15" and bringing along the psd2002 with the h290. i'd love to try the jbl's but am concerned if the box is right for this driver. the woofer cutout is 14" so it should fit.
cheers,
george
Re: cabinet maker screwed up again [message #35534 is a reply to message #35525] Sun, 17 March 2002 11:52 Go to previous message
mikebake is currently offline  mikebake
Hey Bill, remind me what you are bringing......if you want to use a pair of my 3115's so you don't have to haul yours, let me know.
Previous Topic: Theater 4Pi's rockin tha house
Next Topic: M-252-8B2 at Tent Sale
Current Time: Sun Sep 20 12:42:47 CDT 2026
