Home » Sponsored » Pi Speakers » Active crossover vs passive crossover
Active crossover vs passive crossover [message #35510] Fri, 15 March 2002 12:56
Rudi is currently offline  Rudi
up to about 500w rms using a passive crossover whether it is,2 way, 3way,bandpass,highpass,lowpass,1st order,2nd order,3 rd order,4th order it is cheaper for up to 500w rms.
But when it is over 500w ,use an active crossover which is cheaper than the passive crossover at 500w and above. Also the active crossover is better than the passive crossover,cos you can adjust the roll off point,and limit the frequencies.
So for example a 50hz-5 khz driver can be limited to 50hz,so 50hz and below doesn't damage the driver,also at this point you can crossover
to a sub bass bin - 20hz or so
Previous Topic: Crossover Doc Spcie models
Next Topic: now i know what to do with my crawlspace
Current Time: Fri Nov 06 02:03:17 CST 2026
