Home » Sponsored » Pi Speakers » C5 & R3 values - accuracy of driver
C5 & R3 values - accuracy of driver [message #35502] Fri, 15 March 2002 04:05 Go to next message
Super_BQ is currently offline  Super_BQ
Hello Wayne,
I'm curious on the accuracy of my Eminence Delta 15A woofer (used in Theater 4 Pi speaker xover). On their spec. page they show:
Coil Inductance (Le) = 0.86 mH
Coil Impedance (Re) = 6.9 ohms
Using the above, C5 = 18uF and R3 = 8.625
But when using my LCR digital multi-meter to measure the actual woofer I get:
Coil Inductance (Le) = 0.66 mH
Coil Impedance (Re) = 6.5 ohms
Using the above, C5 = 15.62uF and R3 = 8.125 ohms
Should I use C5 & R3 values that I measured with my LCR meter or should I just stick with say a 20mH inductor as mentioned from other previous posts? Is it that Eminence's specification shows a "nominal" value and what I get with my LCR meter will be different?
Brendon
Re: C5 & R3 values - accuracy of driver [message #35506 is a reply to message #35502] Fri, 15 March 2002 08:49 Go to previous messageGo to next message
dbeardsl is currently offline  dbeardsl
Hmm.. thats really odd that the inductance is off, try measuring a known inductance to make sure yer meter isn't funny. Thats mainly a function of voice coil winds and diameter, don't how that could change much from unit to unit...
I'll let Wayne tackle the "She needs a 15.62uF cap, She needs it not, She needs a 16.52uF Cap, shee needs it not" problem
Re: C5 & R3 values - accuracy of driver [message #35509 is a reply to message #35502] Fri, 15 March 2002 11:15 Go to previous messageGo to next message
A Zobel woofer damper is a very wide tolerance device. You can change values a great degree and not detect a difference in performance. See pages 61 and 62 of the crossover document, where it shows the difference between a damper using 7.35 and 10 ohms, and 20uF and 24uF. You can't tell 'em apart.
Re: C5 & R3 values - accuracy of driver [message #35514 is a reply to message #35506] Sat, 16 March 2002 05:23 Go to previous messageGo to next message
Yes my LCR meter is pretty accurate (at least for the inductance goes). I also find it funny that both drivers are not identical spec (with reasonable variances). For each speakers i get an:
Le of 0.66mH & 0.64mH
Re of 6.5 & 6.4 ohms
So for C5 i've installed 15uF Solen capacitor and for R3 I used 7.5 ohm resistor.
Also just finished doing a super duty bracing for the cabinets and letting it set as we speak. Will give a final review after good break-in.
the past [message #35516 is a reply to message #35502] Sat, 16 March 2002 11:13 Go to previous messageGo to next message
Are these the same speakers you said sounded thin a while ago? if so, what did you do to fix them?
Re: the past [message #35522 is a reply to message #35516] Sun, 17 March 2002 00:22 Go to previous messageGo to next message
Yes they DID sound thin but after doing a super bracing effort on both speakers and RE-DOING the xover - it MADE A WHOLE WORLD OF DIFFERENCE! - will post pictures soon.
The Theater 4 Pi aren't really broken in yet but so far.. they are quite dynamic and fast in sound.
Right now i'm a little annoyed of mis-placing 4 of the woofer screws...
Cool! [message #35524 is a reply to message #35522] Sun, 17 March 2002 00:36 Go to previous message
When you get the pics, post a link or email them to me, I'll pass em to the Pi Pictures site.
Previous Topic: now i know what to do with my crawlspace
Next Topic: Theater 4Pi's rockin tha house
Current Time: Thu Sep 12 17:20:18 CDT 2024
