Home » Sponsored » Pi Speakers » i think i've found the subwoofer for my jbl 4655's
Re: kappa 15lf vs kappa 18 [message #35480 is a reply to message #35477] Wed, 13 March 2002 17:39 Go to previous messageGo to next message
I've run the Kappa's with the PSD 2002's and they sound fine to me. I've run them in both standard and pi horn applications.
I've used quite a few of these drivers, and from the standpoint of someone with plenty of experience with them, I really can't recommend them for subwoofer duty. They'll be alright, you can probably get flat response to 35 Hz, but there are better options IMO.
Adam
Whoops! [message #35481 is a reply to message #35479] Wed, 13 March 2002 19:54 Go to previous messageGo to next message
Colin Fritzke is currently offline  Colin Fritzke
Wayne,
You're right... I DID mean to say the Kappa 15LFA was the driver with the nasty peaks in FR.
Good eye!
Colin
Re: kappa 15lf vs kappa 18 [message #35482 is a reply to message #35480] Wed, 13 March 2002 20:05 Go to previous messageGo to next message
Ok, perhaps I was a little bit hard on the Kappa 15LFA's for two-way duty. I just chose NOT to use it because I found a better alternative... the Kilomax 15 at a sweet deal :) I'm sure the Kappas do sound quite decent with the PSD2002.
That said, I still think that the Kappa 15LFA WILL make a decent subwoofer. Not one with the deepest extension in the world, but a sub that will fit in a cabinet that is acceptable size for a livingroom. Like I said earlier... there WILL ALWAYS be a trade-off between efficiency and deep bass when it comes to subs. If high efficiency AND high SPL is the goal, prepare to have absolutely HUGE cabinets. Most people I know can't tolerate anything bigger than 5 cubic feet for a subwoofer unless its in a dedicated home theater room. If I was building a sub for myself to go with high-efficiency mains, I'd go with an Adire Audio Tempest or dual Shivas with a BIG amp.
FWIW, that is just my opinion.
Colin
Re: kappa 15lf vs kappa 18 [message #35546 is a reply to message #35472] Mon, 18 March 2002 12:47 Go to previous message
freddyi is currently offline  freddyi
Hi George - without added source Z your driver would be 8.4cu.ft. QB3, f3~34Hz, fb~29Hz - could probably lop a bit of volume off and tune a bit lower - if it sounds good - have 95oz older Eminence kinda like Sigma with 3" voice coil and qts close - they have pretty good subjective definition in my 6.4cu.ft R-J style boxes but was using solid-state - wish could help on Eminence 15" - only have Delta Pro and discontinued 295-070 Dayton - freddy
Previous Topic: 6 pi theater corner horns
Next Topic: Might actually get to build 10 Pi's this summer!
Current Time: Fri Nov 06 07:32:01 CST 2026
